Ir para o conteúdo principal
Modelo de TV: LD4655VX, retroiluminação LED, 46"
HDMI Ports Not Working w/ Amazon FireStick
No Connection to HDMI Ports on 46 in HDTV Westinghouse.Amazon Firestick is not displaying anymore I switched to HDMI 1, HDMI 3 & HDMI 2 was not connecting. Now, none of the HDMI ports are even connecting to the Amazon Firestick. No display is showing of any tv shows or programs. Blank screen!
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Do the ports work with any other HDMI source?
por
Adicionar um comentário
1 resposta
The HDMI cable you're using might be malfunctioning or too old to perform adequately. Try a different HDMI cable to see if it solves your issue. Alternatively, you can use the first HDMI cable to connect a different video device to check if the video device is malfunctioning.
Regards,
Will
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
JesusChristisLord GodIsGood será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 390
