Ir para o conteúdo principal
Adaptador de alimentação CA magnético de 2ª geração para produtos MacBook, lançado pela primeira vez em 2012. Não é compatível com sistemas da geração anterior. Disponível nas versões de 45 W, 60 W e 85 W.
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Imagem
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
Imagem
Esta resposta foi útil?
Pontuação 6
16 comentários:
So the output from both Power pins must be around 20V?
I have 85W charger.
por Compartilhar
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
por Compartilhar
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
por Compartilhar
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
por Compartilhar
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
por Compartilhar
Exibir mais 11 comentários
Adicionar a sua resposta
Yurii Chaikovskyi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 144
Ao todo: 13,558
