Ir para o conteúdo principal
Screen keeps flashing white screen with apple logo on and off
Replacement of battery and screen for my iphone 6 and screen keeps flashing white screen with apple logo on and off not turning on I evern try the power button and home button trick nothing happened please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
shavell hines, Did you do the replacements yourself? If not, take it back to the shop that did and show them that the device is boot looping.
If you did the repair, it’s time to open it back up and doing a few things. Inspect very closely for any unintentional damage you did when replacing the screen and battery. Torn flexes, components, etc. If there are no obvious damage, unplug the new battery and put back the old battery (if you still have it). If it still loops, you have removed the battery as a cause. If it boots up normally with the old battery, you have located that the new battery is at fault. Even the best of manufacturers will have a bad apple in the bunch. No one is immune to defects. You can also plug in the lightning cable without a battery plugged in, which should prompt the phone to boot immediately, and see how it behaves.
The first thing I usually do when facing an issue like this, is to unplug all connectors and clean them all with >99% isopropyl alcohol, then reseat them making absolutely sure the connections are good. (Experience has taught me that I never close a phone back up until I have tested everything successfully.)
Since you’re seeing the Apple logo in the boot loop, the cause is almost certainly not the screen, but unplug, clean and reseat the connectors anyway. Better safe than sorry.
Esta resposta foi útil?
Pontuação 2
Hi Shavell,
I'm starting with the assumption that you did your own battery and screen replacement, so let me know if that's incorrect.
As well, I'm guessing you weren't seeing that behavior before the replacements, so the logical conclusion is that the problem is related to your repair somehow. The most common issue we see in cases like this are the flex cables not being fully or correctly plugged, although occasionally we see that a cable or connector was damaged during the repair.
So the first step here is to retrace the steps of your repairs and unplug, check, clean and reseat all of the the connectors you unplugged during the repair. That's going to include the battery, digitizer, LCD and home button connectors. Examine each one with a magnifying glass and a bright light for bent or broken pins or dirt or foreign objects interfering with the connection. Bent pins can frequently be straightened with fine tip tweezers if any are found. While you're at it, check the flex cable going to each connection for any signs of damage; tears, gouges or nicks in them.
Next, you'll want to take some 90% or higher isopropyl alcohol and clean both sides of the connectors; the one on the logic board and the one on the cable. Plug the cables back in carefully, paying special attention to the notes on steps 17 and 18 of the iPhone 6 Battery Replacement guide regarding the display cable popping off and the proper way to reconnect those long plugs.
Once you've got everything reconnected and the covers back over the plugs, retest the phone before securing the screen down and see if the problem has been fixed.
If not, you may have an issue with the replacement battery or screen. Try putting the old ones back in one at a time and see if the problem is still there.
After you've done all this, get back to us here and let us know what you find. If the problem still hasn't been resolved, we'll figure out what to do next to help you.
Pontuação 1
Adicionar a sua resposta
shavell hines será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 193
