Ir para o conteúdo principal
Device repair and information for the Vizio D-series 50" LED television with model number D50n-E1.
20 Perguntas Visualizar todos
My tv has multiple lines going across is horizontally
My tv doesn’t even do this when I first turn it on but soon it gradually starts to glitch out horizontally. If I leave it on long enough it stops and then just comes back. It just started doing this and I haven’t touched or moved it at all. Unplugging it gives me 20-30 minutes without the flashing. I forgot my pin so I can’t factory reset it.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
darken this looks like a failure with the LCD driver board (in particular with the Gate Drivers). Those boards are not replaceable and are considered to be part of the panel. There is a slight chance that this could be related to the mainboard (GPU failure). I would try and get an inexpensive (maybe used) main board and see if that will help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
darken será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 99
