Ir para o conteúdo principal
Tc-p50st50 flashes 6 error code
I have a 2012 Plasma that will go into a lockout with 6 error code flashes, I can reset it using the power button on the tv, it will sometimes work for a week following the reset before doing the same thing, the next time the reset may only before a matter of seconds. I have checked the boards for signs of failures with not obvious problems. The troubleshooting for 6 flashes states that the most probably fault is the sc board, with the next most probable being the “a” board. I am uncertain how to determine with certainty which board is causing the problem. I did check the boards for loose screw grounding connections, there are signs of arcing in a few locations. Any help on how to proceed is appreciated.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @kwm
Here's an image that shows how to troubleshoot a 6 blink error code to know whether it is the SC board or the A board that is the problem in your model TV.
(click on image)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks I will give that a try,
por
Adicionar a sua resposta
KevinM será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 448
