Sanyo DP50747 tv power issue
t
Tv started turning its self off . let it sit and could restart with remote did this three times . stopped using it and now no power to screen . Could this be that ft8ah250vp fuse as well ?
Esta é uma boa pergunta?
t
Hi @kjc11
Start by going through the no power troubleshooting flowchart and check what it shows.
Esta resposta foi útil?
ill try the fuse first as it sounds like other persons issue was resolved with it
If it was the fuse you quoted in your question, once it blows it is blown and it doesn't reset again and this doesn't correspond with what you said about it being able to restart again albeit without a screen
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 30
1 comentário
Can you take the back off the TV and upload pictures of the circuit boards inside? Adicionar imagens a uma pergunta já existente
por Andrew S
