Replacing hard drive with ssd drive
Can someone give me instruction on how to replace hard drive with ssd drive?
Esta é uma boa pergunta?
https://youtu.be/watch?v=EKzqMIC8nUI - to remove top cover and
https://youtu.be/watch?v=M-ynZ5m1bR4 to remove drive. The optical disc bay is removed by taking out the small screw on the bottom ( the one he didn't instruct to remove. )
You may have already fixed this, but this is the top result on Google and others may use it.
Esta resposta foi útil?
As long as you have the right ssd drive, its a simple swap. Remove the old hard drive, replace the new ssd. It was 2 cables for SSD on my PC but for some Laptops its just 1 connector
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 489
