Ir para o conteúdo principal
Replacing hard drive with ssd drive
Can someone give me instruction on how to replace hard drive with ssd drive?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
https://youtu.be/watch?v=EKzqMIC8nUI - to remove top cover and
https://youtu.be/watch?v=M-ynZ5m1bR4 to remove drive. The optical disc bay is removed by taking out the small screw on the bottom ( the one he didn't instruct to remove. )
You may have already fixed this, but this is the top result on Google and others may use it.
Esta resposta foi útil?
Pontuação 1
As long as you have the right ssd drive, its a simple swap. Remove the old hard drive, replace the new ssd. It was 2 cables for SSD on my PC but for some Laptops its just 1 connector
Pontuação 0
Adicionar a sua resposta
Steve Truitt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 489
