unmarked component identification help
what is it?
measures 119.8v ac on both sides.....
comes off of the board here:
its normal path from pcb ... usually mounted behind the fan....
wtf?
Esta é uma boa pergunta?
what is it?
wtf?
That would be a thermistor; basically a resistor whose value changes based on temperature, used to regulate the heat output. Here's a page from DigiKey showing the wide variety of values available.
Esta resposta foi útil?
that explains its presence at the fan intake. thank you
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 282
