How do I fix a lamp with a short? The bulb flickers on and off.
my floorlamp bulb flickers on and off and only holds a light if balanced in a specific position. i think there is a short in the connection. how to fix?
Esta é uma boa pergunta?
Just try replacing the lightbulb 💡
Esta resposta foi útil?
I tested the bulb, of course, on another fixture. It's fine. And the lamp is plugged in.
Then I guess you should consider replacing the lightbulb socket, but can’t say more specifically until we see an exact unit
@mcb48 if changing the bulb does not help you may need to check the wiring in the light fixture itself. Remove the bulb (unplug your lamp) and take a picture of where the bulb normally sits. And one of the bulb itself. that way we can see what fixture your lamp has and hopefully can be more specific with our answer.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 63
