Ir para o conteúdo principal
A terceira revisão do clássico Controle Sem Fio Xbox foi lançada em novembro de 2020, acompanhando o Xbox Series X e Series S. Este controle é compatível com versões anteriores dos consoles Xbox One e PCs.
Problem with LT and RT always pressed
The left and right trigger always keep pressed, this problem began when i replace(
solder and desolder) both stick, first right stick and the controller works normally but when i replace the left stick the problem began.
This video show better the problem(this is the official xbox app): https://1drv.ms/v/s!AhpypwlrW5KohIBgdkgz... as you see the lt and rt button keeps pressed but the others works normally and this is another video with other app(the problem is more visible with this): https://1drv.ms/v/s!AhpypwlrW5KohIBhcMTA...
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
4 respostas
Pergunta mais útil
I just came across this problem on LT and fixed the problem by replacing the U11 component (303 hall effect sensor for the trigger) with an old xbox one controller 304 hall effect sensor.
Esta resposta foi útil?
Pontuação 4
2 comentários:
Just wanted to say thank you for this! I didn’t need to replace it but reflowing this chip fixed the issue for me! I wouldn’t have even known to touch this component had it not been for your comment.
por
@stuffmonster I'm glad I was able to help someone with this solution. One less controller in the bin. 😎
Thank you!
por
Check U9 controller on a board. On output should be 1.4V. I have a solution but it's not very nice. Connect output trace with 3.3V. It worked for me but I don't guarantee that it will work for a long time. You could also replace this IC. Problem is that it's a very small piece and it is easy to burn using hotait. Sometimes this IC doesn't have any specifications on it (especially in 1708 and older) so proper resoldering it can be quite tough
Pontuação 0
2 comentários:
do you mean inject voltage on the trace to fix it?
por
Yes. It helped. I don't remember where specifically I connected it, it was a long time ago. Maybe before a voltage divisor if there was. I remember that those sensors have common power so if there is no power, they both don't work.
por
WERE you able to fix it?
Pontuação 0
If anyone encounter problem with LT and RT trigger always pressed, replace U9 controller, for me it worked, and I even used U9 chip from Xbox One controller and soldered into Xbox Series Controller and yes it worked if someone was wondering.
Pontuação 0
Adicionar a sua resposta
rafaeljevi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 52
Últimos 30 dias: 218
Ao todo: 5,647
