Ir para o conteúdo principal
Um celular fabricado pela Samsung com Android 6.0 SoC Qualcomm Snapdragon 430 Octa-Core de 1,4 GHz Tela de 5" com resolução de 1280x720p 16 GB de armazenamento interno (expansível)
The process com.android.phone has stopped
This error keeps coming up when I press OK it comes back constantly even after clearing data for the phone app how do I fix this without reseting it?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I have a ONN tablet,no phone yet I get this message all the time
por Compartilhar
@sandratibbetts It actually doesn't matter what device you're using, whether it's a tablet or a phone; what they have in common is the Android operating system, which is where your software error is coming from. Does your tablet have a slot for a SIM card?
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
If you see the error message “Unfortunately, it has stopped
process.com.android.phone
or unfortunately stop
com.android.phone
Process after installing ROM
If you are new or update your firmware, there are actually several ways to fix it
The error message is triggered by phone or SIM toolkit app
So, if you are constantly getting the “Unfortunately, the process com.android.phone has stopped” error.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Solution #1: Disable automatic date and time
This simple setting change can help you remove the error message for good. To change this, go to Settings from the Home screen, then tap
por Compartilhar
Second solution: Clear data and cache
Third solution: Clear data and cache
Boot the device in Safe Mode
por Compartilhar
Adicionar a sua resposta
80stechkid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 60
Ao todo: 1,123
