Ir para o conteúdo principal
Mouse Bluetooth da Microsoft, parte da família de periféricos de computador Sculpt.
Mouse is not moving on the Screen
I put new batteries in mouse, Blue light is on along with Green light but mouse does not move on screen???
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Did it work fine before old batteries died out? If it's the first time you're using it on your PC, did you install the required drivers correctly?
por
Adicionar um comentário
1 resposta
Check that the battery of the mouse is charged. Make sure that the receiver (dongle) is firmly plugged in to the computer. If your mouse and receiver can operate on different radio channels, make sure that they are both set to the same channel.
Regards,
Will
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tammy VT será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 696
