Ir para o conteĂşdo principal
Repair and disassembly information for the Samsung Galaxy Note20 Android smartphone. Released in August of 2020.
Temperature Triangle of DEATH 💀💀💀
I got the phone and it was great till it wasn't. When I went to charge it the battery logo woukd start blanking so I powered it off and got a yellow triangle with a thermometer and it won't charge, what should I do I just got it.
Esta Ă© uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais Ăştil
@sly64 looks like a common issue with Samsung phones. For now I'd take the battery out and clean the USB port. If that does not help, consider first getting a new battery and second, replacing the daughterboard. There is also a possibility that this is a torn NFC flex, which can cause this to happen as well.
Esta resposta foi Ăştil?
Pontuação 1
You say you’ve just got it. New? If so go the warranty route first. As soon as you open the phone your warranty is gone.
Pontuação 1
Adicionar a sua resposta
Graham será eternamente grato(a).
Visualizações:
Ăšltimas 24 horas: 1
Ăšltimos 7 dias: 8
Ăšltimos 30 dias: 29
Ao todo: 1,294
