Ir para o conteúdo principal
Headset not powering on
Hi
I have tried to use my headset with the usb plugged in to charge whilst in use steel series arctic 9x it worked for a few minutes then went off and I’ve not been able to power them up since
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
First, try changing the cable or testing it with another device to ensure it works. If not there is a pinhole under the ear cushion (non-mic side) that has a reset button. Use a paperclip to press down into it to reset the 9X. You should feel a circular bump which is the button. If this doesn't fix it, download the SteelSeries Engine from https://steelseries.com/engine to a desktop/laptop and update the headphones.
Imagem
Esta resposta foi útil?
Pontuação 1
1 comentário:
Had the same issue. It stoppped functionning a couple of months after buying it. Managed to get a new headset through warranty but 3 years later it did it again. Faulty model I presume
por
Adicionar a sua resposta
Alan Stanley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 48
Ao todo: 5,240
