rear cover of the keyboard bent on left rear corner
I lent this laptop to a family member (the fans were loud before but they went on and off every five minutes then and now its constant lol) and when they gave it back the back corner was very flimsy and the entire left side of the rear casing of the keyboard is sort of cracked open, but the computer works still works fine and i have no idea how this happened as it was given back to me in this condition. I have unscrewed and re-screwed the screw on the back on, but it didn't help. does anyone have at least a guess on what is wrong?
(don't mind the crappy camera quality as my iphone 7 is broken and had to use a different device as i refuse to submit to apple trying to force people to get new iphones every year lol)
also i think it may be a pin inside knocked loose or a dent that the casing overcame but the side casing might have not and caused this pushing out of the back casing, or the battery is swelling .-.
edit i have removed the rear casing and something is wrong with the hinge in this photo .-.
when i first unscrewed it the hinge popped out aggressively before i got to pull the cover off lol
@oldturkey03 I FOUND OURT WHATS WRONG YAYYYYY
a screw holding the hinge is loose .-.
the thing holding the screw isn't connected to the computer and where it should be is a hole straight to the bottom of the keyboard .-.
note: it only bends while its closed and closing becuase the loose screw is pushing as it does not want to close
also the fans are not loud anymore after putting case back on?????? weird lol
also when i first put the case on, the flash for the camera was on until i powered it down, does anyone know what was that about????????
Esta é uma boa pergunta?
3 comentários
@timtomissus add some pictures of the damage to your QUESTION. that way we can see what you see Adicionar imagens a uma pergunta já existente
por oldturkey03
I added the photos you requested, ask me if you need anything else :-)
por timtom77
all of my screw drivers are either to small or to big :(
por timtom77
