loud snapping cracking sounds every now and then
I have the same problem, the monitor would make loud snapping cracking sounds every now and then. Is there anyway to check the Caps or resistor visually as I'm not an electrical engineer, but can sort of solder a component if I need to.
Esta é uma boa pergunta?
1 comentário
Ian D. Mah let us know what model your monitor is. you can also post pictures of your boards with your QUESTION. That way we can actually help you a bit better by pointing to things etc. Adicionar imagens a uma pergunta já existente
por oldturkey03
