Ir para o conteúdo principal
The Razer Blade 15 (Base Model, 2020) Model Numbers: RZ09-0328 The 2020 Razer Blade 15 Base Model is a high-performance gaming laptop featuring a 10th Gen Intel Core i7-10750H processor, 16GB of RAM, a 144Hz 15.6" Full HD display, and an NVIDIA GeForce GTX 1660 Ti GPU. Designed for smooth gameplay and creative workloads, it’s a sleek, powerful machine built for serious users.
Can the trackpad be replaced?
The trackpad was cracked by a swelling battery and I was wondering if it was possible to replace
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Hi @lonestarr,
What is the full model number of the laptop as shown on the product label on the bottom of the laptop?
por
Hi! The product number is as follows:
RZO9-03287322
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @lonestarr
You should be able to replace the trackpad if you can find a replacement part that is.
Here's a video that shows how to dis-assemble an RZ09 model which should help to gain access to the trackpad. (not exactly the same full model number but should be close enough)
Finding a replacement may be harder though. Found this one but it is for a different model number. Maybe it's the same I don't know. You may have to check if there is any information on the trackpad itself, e.g. part number or model number etc and search online using that information to try and find one.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Jesse Mills será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 82
Ao todo: 2,368
