Ir para o conteúdo principal
Repair guides and support for Olympus digital and film cameras.
Help! my camera just started bugging out
I own a Olympus E-620. Now I don't know A whole lot about cameras, past the small photography class from HI school , and I've had this one for a few years as a gift being my first camera and I've never had a problem with it for the 5+ year I've had it. Now the problem I'm having is when I turn it on and get ready to take a picture the camera won't do anything but auto focus. But the weirder thing is when I go in live view the screen is all green and fuzzy but the hud with all the settings is there. Than after a few seconds in live view the camera resets over and over and occasionally I'm able get into the menu. And when I do sometimes the screen is zoomed in where almost nothing fits in screen. It's never done this and it hasn't been damaged much more than being dropped once from what I know of and that's when my uncle had it first. I don't have the money atm to get a new camera and If someone could help figure this out it would be much appreciated. here's what the screen looks like
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @nexx,
Try a power refresh and check if that resolves the problem:
Turn off the camera if it is on and then remove the battery from the camera. Turn the camera back on for about 30 seconds using the on/off switch. I realize that the camera won't turn on as there is no battery installed but what this does is it resets the camera's software back to default in case there was any corrupted data being stored.
Switch off the camera, reinsert the battery and check if it works OK.
If it works OK you may want to think about replacing the battery as sometimes when batteries start to fail it can cause problems. If it doesn't work then you still may want to think about replacing the battery. Even rechargeable batteries have a lifespan and unless you replaced it recently, it may be reaching the end of its usable life.
Has the camera been dropped or gotten wet at all?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Iain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 386
