Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 12. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 12.
Screen is dark after replacement and face id not working
I replaced the OLED on my iPhone 12 and the screen is super dim and i am unable to adjust it to be brighter it is just stuck. the face id has also stopped working. what do i do here? is there something i can fix without costing me a lot of money?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
when you swapped the flex over from the old screen to the new screen was there anything covering the front lens on the back of the new screen
Esta resposta foi útil?
Pontuação 1
It’s your ear speaker ribbon causing the problem. I’ve just had one with exactly the same issue. Disconnect the battery first. Then disconnect the ear speaker and screen ribbons again. Reseat everything then see if it works.
Pontuação 1
Have you updated your phone to ios 16 before you did the repair?
If so you will have to flash it back to ios 15 for any screen replacement to work.
Pontuação 0
Adicionar a sua resposta
Ashton Grabow será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 284
