Lenovo Ideapad won't turn on after I replaced the SSD
I have an Ideapad that is about 7 years old. It worked great until I opened it for the first time to replace the SSD with a bigger one. I was very careful when opening it, and didn't mess up with anything else other than replacing the old SSD with a new one. After that, the laptop won't turn on anymore. I even put the old SDD back to see if it would work, but it simply doesn't turn on. I press the power button, and nothing happens. Any idea?
Update (10/30/2022)
Ideapad Y700 Touch 15"
Unfortunately, I didn't disconnect the battery from the motherboard before replacing the SSD.
It doesn't show it's charging when I plug in the charger.
Update (10/31/2022)
Esta é uma boa pergunta?
1 comentário
Hi @srgbrg,
What is the model number of the laptop?
Did you disconnect the battery from the motherboard before changing anything inside the laptop?
Does the laptop indicate that the battery is charging when the charger is connected?
por jayeff
