iPhone in Recovery mode
I just found out that my Iphone is in recovery mode. I have no idea how to get out of recovery mode or how to fix it. What do i do?
Esta é uma boa pergunta?
It looks like just shutting the phone off then turning it back on should pull it out of recovery mode. If that doesnt work you will need to connect to your computer and recover it. This option is fine so long as you have backed up your phone recently, otherwise you will lose any information you've acquired since the last back up. Holding the home and power button seems to be another option.
Hope this helps, good luck.
Esta resposta foi útil?
There are several options as to how you can get out of this mode. You can do it manually which is a bit harder for beginners or use a one-click tool like this one and it will get the job done for you.
Let me know if you need further help
Method 1. Fix iPhone stuck recovery mode with iTunes. (Data Loss)
Method 2. Fix iPhone stuck recovery mode with iOS System Recovery. (No data loss)
iOS System Recovery Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 457
2 comentários
turning it off didnt work, so i restarted it and that helped. thank you
por Rahaf
Normally if your iPhone is in recovery mode, you need to connect your iPhone to your iTunes and the iTunes will tell you that your iPhone is in recovery mode, you need to restore it with iTunes.
However, some times, you can not restore your iPhone successfully with your iTunes. Here is an article to show you how to get your iPhone out of recovery mode.
por bethzac5
