My Laptop Y11c is turn off suddenly
Hi
My latop turn off suddenly Now it wil not power on
No blue light is blinking
No screen is Displaying
Esta é uma boa pergunta?
Hi
Musa Mumtaz start by checking your AC adapter. Make sure that you have 12 Volt on the barrel adapter. You can measure that with a multimeter set to 50V DC Red probe inside the barrel and Black probe on the outside. It should show 12V when plugged it. If it does, then go ahead and check the DC-In jack on your computer. Make sure that is in good working order. The port is soldered to the circuit board, so you will have to get into your Y11c. Use something like this for your guide.
Esta resposta foi útil?
doesn't it have an indicator for charging?
If it isn't lit, then it isn't getting charged.
First suspect is the charging block. First failure would be a broken wire near the laptop connector. The components in the box would be the next. Either would require replacing the charger.
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 221
