Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
552 Perguntas Visualizar todos
Display replacement for MacBook Pro Late 2013
Hi,
I am looking for a display replacement for my MacBook Pro, but the prices are way higher than the value of the computer.
So, I have some questions:
  1. Do you know where I can find a display for this Macbook at reasonable prices (a fully function MacBook pro like mine costs £200)?
  2. Are there 3rd part displays, non-retina that, could fit in this computer? An IPS or similar display.
  3. Is it possible to repair a damaged screen? (I doubt it ... but it is worth asking)
Thanks a lot.
Please check the image attached.
Best regards,
Pedro
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Sadly, there isn’t much you could do except pay the price for a new display or a new Mac. I am not aware of any third party displays. You could take a gamble on a broken Mac and see if the display is ok but that can be risky. It may be about time to start looking for another computer or use it with an external monitor as a Mac mini.
Esta resposta foi útil?
Pontuação 1
Here’s one source for the full display https://www.thebookyard.com/parts-retina... the cheaper ones at least work better than your current one.
While not easy you can replace the LCD panel alone. Follow the MacBook Pro 13" Retina Display Late 2013 Display Assembly Replacement then reference this teardown MacBook Pro Retina Display Teardown I’ll need to dig through my files to get the LG part number for this model..
Imagem de MacBook Pro 15" Retina Display Mid 2012
Guia
Nível de dificuldade:
Moderada
Imagem de MacBook Pro 13" Retina Display Late 2013 Display Assembly
Guia
Moderada
30 minutes - 1 hour
Pontuação 1
Adicionar a sua resposta
Pedro Cardoso será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 51
