Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 6 do Google, lançado em outubro de 2021. Identificado pelos números de modelo GB7N6 e G9S9B16.
Pixel 6 touch screen less precise after replacement
I have had my Pixel 6 screen replaced after a big crack.
After finally fixing the fingerprint sensor issue, I still find myself with a major problem:
The touch screen is less "precise" when typing fast. Namely, when I am writing fast and touch the screen in two points almost simultaneously, it interprets it as a "swipe", and therefore misses the first of the two touches.
This had never happened before the change. Is this a known issue, or could it be a problem with the new screen itself?
Thanks!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Pergunta mais útil
This is likely a defective screen. See if you can get a refund or replacement. If it was a cheap screen, it may just be very low quality.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks, that was also what I thought. It was however not a cheap one, and was (according to the seller) an original piece. Will ask for a refund
por
I have this same issue and also when I call someone the screen flickers
Pontuação 0
Hi. I don't have an answer, but I also got my screen (only the touch part) replaced by a third party (Pixel 6 wasn't launched in India) and have the exact same issue. How did you fix it?
Pontuação 0
Adicionar a sua resposta
Davide Di Nello será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 1,160
