Ir para o conteúdo principal
A versão de lançamento da série C2 da Nokia, com suporte a dois chips (dual SIM), lançada em 2011.
Accessing memory of dead phone
Hi, my Nokia c5-01 got dead without any life signs. I want to know if i can access his memory with an adapter or something like this. This is an old phone, from 2012.
Thanks!
Esta é uma boa pergunta?
Pontuação 2
6 comentários
@tcbr10 it's really not possible for the common DIY'er to get to the memory. It'll be best to try and get it to power on and then remove/backup the files the common way. Start with what @strongbow is suggesting.
Here is the troubleshooting flowchart for your phone for the No-Power situation
[image|2765098]
Nice to see this phone actually had a fuse by the power cable connector!
Here is the component layout Component for your board. Again, this is just supplemental information to the answer given by @strongbow.
por
thanks for the answer! my phone is nokia c5-01 i chosen c2 becuase this is the most same phone i found in the list, c5 wasnt there... you know if the memory is encrypted in this phone? and you have a component doc for this phone?
i tried using another battery but it didn't worked...
very very thanks!!
por
@tcbr10 ah. Yes, I see that now. I believe I have those documents as well. As soon as I get home I will add those.
por
thanks! i will be glad for the correct troubleshooting as well, thanks!!
por
@tcbr10 of course it never fails. I have anything but the 01 variant. Let's see if we can use the rest of the C5 family to figure it out. All the tests ask first for a current consumption test. You need a ammeter you can connect between your phone and your charger. Replace the battery and see what you come up with. If nothing else you could take a picture of the main board and post with your QUESTION that might allow us to identify more of the circuitry and the components. Adicionar imagens a uma pergunta já existente
Looks like it might be possible to do a memory dump with one of the flasher boxes that are still for sale. those files will of course not look like anything that you and I could just read. Seem to get harder to come by and way more expensive, then it might be to repair your phone.
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Pergunta mais útil
You’re probably better off trying a new battery if it still has the original in it. I have a Nokia 8310 and got a new battery. Now it works great.
Esta resposta foi útil?
Pontuação 3
it's not supported for the bios to run 3g and 4g it's a 1g and 2g network phone u can use the Wi-Fi but i mean the hardware isn't really compatible with a lot of the new tech I'm sorry I don't understand the question but there's a little info for u it would be hard to really use it now so many upgrades you're pretty much making a new phone but at least u can use the Wi-Fi is u use the right frequency's
Pontuação 0
Adicionar a sua resposta
Tcbr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 532
