Ir para o conteúdo principal
Lançado originalmente em outubro de 1993, o FZ-1 R.E.A.L. Interactive Multiplayer foi fabricado pela Panasonic usando especificações de design da The 3DO Company.
Panasonic 3DO FZ-10 factory modchip?
Imagem
Imagem
I was tearing my 3DO down and noticed what looked like a modchip but it looks so well done that I am not sure if it is from the factory or not so hopefully someone can help me with this.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@cwr81 looks like an aftermarket RGB Mod. Remember that real modders take a lot of pride in their work and are true artists.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Ok cool, does it look right, it had a shorted out power supply so wanted to make sure it was just a faulty psu and not this mod, thank you for your help though
por
@cwr that looks right and should not affect your power supply. You'd e seeing scorching/carbon on the wires or solder points if there would be short on it. Definitely NOT a hack job.
por
Ok just wanted to be sure, thank you
por
Adicionar a sua resposta
Nascar1243 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 803
