Ir para o conteúdo principal
My phone display shaking and flickering after dropping
My phone display is shaking up and down (like a glitch) and some parts of the display are black mainly at the corners. I could also see some cracks on the edges of the screen.
What could be the problem and how to fix it?
Esta é uma boa pergunta?
Pontuação 4
2 comentários
شاشة هاتفي بها حبر ازرق وبنفسجى اثر خبطه على الشاشة وكانت صغيره مثل وضع أصبع وبعد ذلك زادت مساحتها بعرض وطول عقلتين أصبع ماهوا الحل بدون تغير الشاشة
por
@Mohamed esawy
The is no other option.
The screen will have to be replaced as it cannot be repaired.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi
When this sort of thing happens it usually means that the display is internally damaged but I have had luck reseating the connector on the board
But because your display has cracks in it it will most likely need replacing
Here’s a guide in replacing the screen for your phone
https://m.youtube.com/watch?v=h9uETgnfzD...
Also here’s the part you will need too
https://www.ebay.co.uk/itm/255668681891?...
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 6
1 comentário:
I'm already replace my display but rather display is automatically touched why is this like ?
por
Adicionar a sua resposta
Ajeeth kumar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 1,028
