Ir para o conteúdo principal
Projetado para funcionar com o Xbox Series X|S e o Xbox One
Why is it beeping?
I recently moved and set my xbox back up. When I power it on the external hard drive makes a beeping sound and powers off. Can this be fixed or do I need to replace it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
When the drive is beeping, that means there is a power issue or it's at the end of it's life. There's some troubleshooting that can be done to see if it's just a power issue
# (The easiest) Disconnect the drive and unplug the cable from the disk and spray out all the ports. There might be some dust
  1. Try another cable. Some cables are better with power and data connection then others
Otherwise, you can run SeaTools. It's a software made by Seagate that diagnoses drives. You can download it here and you should be able to run a test on your drive to see if there is any corrupted data or see the hard drive's life
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dread Head será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 541
