Ir para o conteúdo principal
Lenovo laptop released in 2019, model number 81LW000QSB.
Why is my keyboard getting hot
Lenovo IdeaPad L340-15IRH GAMING laptop and when i play games the keyboard gets hot. Plus the battery drains to fast can you please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
First run some diagnostic software like Speccy or HWMonitor to check if the temps are higher than they should, for reference take a look at the values showed in this full review of your laptop ("Temperature" paragraph). In this case, aside from keeping your laptop on a solid, flat surface while it's operating, here are some possible solutions to the laptop's oveheating problems:
  • check if the fans are working properly, basically you should feel with your hand they're effectively blowing hot air out of the chassis, a software like HWMonitor or speedfan will give you real-time info on the system's fan speeds
  • if the fans are constantly spinning without issue and temps are still too high, air vents could be clogged: assuming that the warranty period has expired, I suggest you turn off, open up the laptop (with all due precautions) and remove all the dust from the inside (refrain from using a vacuum cleaner or air can, use instead an anti-static brush or a dust blower) , especially the air vents (and filters) and fans; while you're at it, replace the thermal paste if needed.
Other tricks that will help you keep your system cooler are:
  • adding a cooling pad to get better airflow
  • tweak the performance settings from the Power Options menu
  • as suggested by @komota, anti-spam/virus/malware software will help you prevent CPU-intensive unwanted apps to run on your PC
  • any missing or worn rubber spacers under the laptop should be replaced
Finally, to get info on your battery's health on Windows, type the "powercfg /batteryreport" command, then simply open the newly created report (it's in your home folder). For more information, check out this article
Hope this helps
Cheers
Esta resposta foi útil?
Pontuação 2
I would say problem is that something is using PC a lot. I would check malware or other software to see what is using pc resources a lot and kill that process, then i will not make heat and then it should work bit faster
Pontuação 1
Adicionar a sua resposta
Dawn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 678
