Ir para o conteúdo principal
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Perguntas Visualizar todos
Will not start up
MY beloved iMac will not start up at all and I get a flashing "file" symbol with a question mark in it. When I use the start up dvd roms to get it to start the hdd is not shown in the disk utilities menu and also the hdd is making odd noises - is my computer completely had it's day at 16 months old!?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
The question mark in the folder means that your computer can't find a system folder. Since Disk Utilities cannot find the drive, it's a failed hard drive. These use SATA hard drives and you might consider upgrading it when replaced. There doesn't appear to be a teardown for this model, but most of this series is the same. I'll try to find one that will help you.
Here's the 20" teardown that should help you: iMac Intel 20" EMC 2266 Hard Drive Replacement
Esta resposta foi útil?
Pontuação 5
2 comentários:
Here's a big boy from iFixit: 1 TB 7200 RPM 3.5" Hard Drive
por
Here's a really big 2 TB: 2 TB 3.5" Hard Drive
por
I think we just had a similar problem. The answer was a firmware password was set. To boot you need to use the option key and enter the password. Here's the URL to explain in detail. Ralph
http://www.macworld.com/article/145418/2...
Pontuação 2
I have the same problem, sometimes the primary partion appeears, sometimes nope
i boot from snow leopard utility and in the disk utility the disk just appears like "media" whitout a brand, capacity or something else
when reboot the machine, everythings is ok, or sometimes i need to press key "D" for diagnostic but everythings its ok
now, i proceed to open the iMac 24 8,1
Pontuação 0
1 comentário:
Please start your own question. Your problem and solution may be entirely different.
por
Adicionar a sua resposta
Adrian Wilson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 6,839
