PC won't boot up
After a bios update my laptop stopped to boot up. The fans are working the caps lock light is on however the screen is black.
I have tried to hold the power button for 30 secs, tried also to press F2 repeatedly after the power on and repeated the same procedure with F12 on another time. But none of the above have worked.
Any idea how to fix this issue?
Esta é uma boa pergunta?
How about F11?
por NR26 Compartilhar
Hi,
Try using a paperclip and press the Novo button (small hole next to audio jack) and check if the Novo menus open allowing you to get into BIOS.
If you can get into BIOS try restoring it to default option and check.
Just a thought.
por jayeff Compartilhar
@nytryder26 I just tried it unfortunately it did not work
por Ahmad Rustom Compartilhar
@jayeff
The reset button did no effect to the laptop 😓
Hi @Ahmad Rustom
Was the laptop unplugged and the battery removed when you pressed the power button for 30 seconds?
Removing battery video:
https://www.youtube.com/watch?v=tWC7wPPv...
por mike Compartilhar
Exibir mais 3 comentários
