Ir para o conteúdo principal
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Error message F5 E3
Washer lid will not unlock. How do I fix or bypass and is that my only issue? Seems like the F5 E3 code could also be another problem.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @appliancedummy,
Please confirm the model number of the washer?
Just in case the reset below doesn't fix the problem.
por
Adicionar um comentário
1 resposta
The F5 E3 alert indicates there is an issue with the lid lock. Do not force the lid open, as permanent damage could occur. Remove any objects from the lid and clear any obstructions. Touch POWER to exit the cycle, then touch POWER again to release the lid.
Regards,
Will
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Appliancedummy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,814
