Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Lighting connector replace problem
I am replacing my lightning connector assembly but I cannot remember where thr two antennas connect on the logic board (or does it not matter)
Does the one from the speaker go on the lower point or the top point on the logic board
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi
The antenna connection are both at the bottom of the logicboard
If you follow this guide
iPhone 7 Logic Board Replacement
On step 33 it shows you where they go
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
4 comentários:
Thanks but the image in step 33 is still not clear which goes where. Is the cable from the speaker the lower one or the higher one
por
@baker-paul16
From what iFixits video shows i think the bottom one is for WiFi and the top is for the the lightning connector assembly
You might also be able to tell from the shape that the cables are bent:-)
por
I agree but be good if anyone can confirm
por
@baker-paul16
Here’s a video for confirmation
https://m.youtube.com/watch?v=GWYV4beNLa...
The longer of the two antennas goes at the top and the smaller one goes at the bottom:-)
por
Adicionar a sua resposta
baker-paul16 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 62
