Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
20 Perguntas Visualizar todos
iPhone stuck in a notification. Unable to dismiss
I accidentaly opened Apple Home, and it showed a critical alerts notification. I tried to press "Don't Allow" but it did not work. Pressing 'Allow' also did not work. All I can think of it to just wait for the battery to die. iPhone is at 90%, on power saver, and has a new battery that lasts almost 17hrs. Is there a way I can either dismiss the notification, or get it to die faster?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you cannot get the phone to power off normally, do a force restart. For a XS press and release the Volume Up button, then the Volume Down button. Then Press and hold the power button until the device shuts off and restarts.
Esta resposta foi útil?
Pontuação 3
9 comentários:
Hello, I have Iphone 12, and have similar issue, notification is not getting closed after Iphone update. How to force start it ..any support you can give
por
@pankaj Force restart for the 12 will be the same process I outlined here for the iPhone XS
por
thanks .. it was a success
por
What if shutting if off won’t work? An alarm noise just goes off from the notification. I have an iPhone 11 with I’m the IOS 16 update
por
Same thing here - were you able to find a fix?
por
Exibir mais 4 comentários
You may use Apple Configurator for Mac app to restart your iPhone - just connect your iPhone to Mac (if you have one of course), right click your iPhone in Apple Configurator for Mac app and choose Advanced - Restart Device.
Official Apple Support guide for this is available here
You’ll find Apple Configurator for Mac app on the Mac App Store as a free download
Pontuação 0
Adicionar a sua resposta
Joesph Dunne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 17,102
