Charging cord doesn't connect
When I plug it in to charge or connect to my car, the connection is very hard to get connected, I have to mess with it and set it just right or it won't connect. What can I do?
Esta é uma boa pergunta?
either fluff or something in the port or its possibly damaged
Esta resposta foi útil?
@treefarm if you find that the connector is actually damaged, you can replace the USB board (daughterboard). Something like this will work. Of course, check the connector coming from your charger first. Something like this video shows you how to get there. Careful on this model. The battery is glued in and a royal PITA to remove.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 154
