Ir para o conteúdo principal
O JBL Flip 5 é uma pequena caixa de som Bluetooth portátil, lançada em agosto de 2019. Ele oferece classificação IPX7 de resistência à água e até 12 horas de autonomia da bateria. Modelo: TT
Why does my speaker not connect
My speaker is not conecting to Bluetooth and it doesn’t on light but it bring sound when I on ot
Esta é uma boa pergunta?
Pontuação 1
1 comentário
hello, i want to discuss this problem as it started happening to my JBL flip 5. (mind my grammar), it was working perfectly fine the day before this happened. first, i connected my speaker to my phone as usual, but it would say it has connected. it did show that the device connected on the JBL Flip 5 with the bluetooth light solid on. but a second or two later, it disconnected. and the same thing happened across all my devices i connected it to, i also referred to resetting the speaker by pressing the plus and play button. but still did the same thing. i don't know if this is an issue with other JBL Flip 5's out there. or its a BT receiver issue, i don't know. if anyone can tell me why my speaker is acting the way it is and/or if there is a way to fix the issue. it would be very appreciated. thanks.
por Compartilhar
Adicionar um comentário
2 respostas
Pergunta mais útil
Try a hard reset
JBL Flip 5 Reset
  1. Power on your device.
  2. Press and hold the play and the volume + buttons at the same time.
  3. Maintain this position for about 5 secs.
  4. The device will power off as it restores to the factory default.
  5. Power on your Flip 5 again, and it will have restored to the factory default.
  6. (copied from the internet 😉)
Esta resposta foi útil?
Pontuação 2
2 comentários:
What a worthless, absent answer. I'm sooo glad this account was deleted. Copy pasting FAQ should be grounds for account deletion. We don't waste our time on a forum until we already wasted our time on your faq. Wasting *more* time finding out that it's *you* saying *that* makes it even more annoying. At what point do we get to charge money to companies for wasting our time with their incompetence?
por Compartilhar
@Dwight Mitchell When someone doesn’t read the faq and asks a question that could have been answered but reading the faq. You get the faq-ing answer.
por Compartilhar
This did not work for me on my flip 5, however I found another answer that said to hold the play and volume down buttons for a few seconds. This resulted in the device powering off and resetting. The device has become responsive again. Hope this helps in case the other method doesn't work.
Pontuação 0
Adicionar a sua resposta
Osho será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 64
Ao todo: 16,727
