Ir para o conteúdo principal
Guias de reparo, manuais e ajuda para solução de problemas da placa-mãe ASUS. Obtenha tudo o que você precisa para reparar sua placa-mãe ASUS sozinho.
Whea Uncorrectable error in my old pc
Hey,
Pc specs
Processor -Intel core 2 duo e7500 2.93 ghz
Ram- samsung ddr2 2gb×2 ram
Motherboard - Asus p5kpl-am in
Psu-230v
Graphics card-Intel integrated g31/33 express chipset family
Storage- crucial 240 gb SSD
So,as of my specs my pc is really old...
When I was using it normally 1 week ago it started showing bsod's.I tried every possible way to fix it but I couldn't and I don't want to spend money
I came to that something called genuineintel.sys is causing this WHEA UNCORRECTABLE ERROR (with the help of who crashed software)
Please help me,I study from that and if it does like this everytime I can't study
Help me🙏🙏
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
So that error likely tells me you have an Intel CPU...Not to worry, I have some ideas.
So first off, make sure that the CPU isn't being overclocked. You can check in your BIOS or if you have software that allows you to change the clock speed, I would make sure it's at the default speed.
I would also run a diagnostics check on the processor
And let's say that your computer wasn't overclocked and the check passes. Most likely it's a bad driver or your BIOS might need an update.
Esta resposta foi útil?
Pontuação 1
3 comentários:
My pc is so old that I don't think they have any bios update and I don't think my cpu is overclocked...Please tel how can I check if it's overclocked or not
por
And the processor is not detected by that Intel processor diagnostic....
I've searched on the internet and this is because my processor is so old
por
I fixed that Whea but two new bsod came that are *Driver irql not less or equal and irql not less or equal* along with Unexpected kernel mode trap something like that
por
Try this steps to fix-
Get all the latest updates with Windows Update. Go to Start > Settings > Windows Update , and then select Check for updates.
Try restoring Windows back to an earlier point in time.
Regards,
Rachel Gomez
Pontuação 1
1 comentário:
I have reinstalled os hundreds of time so I don't have any restore point
por
Adicionar a sua resposta
Playersir5519 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 816
