Ir para o conteúdo principal
Os AirPods da Apple são fones de ouvido sem fio lançados em dezembro de 2016.
How to charge airpods without case
How to connect aripods without case and how to charge them without cass
Esta é uma boa pergunta?
Pontuação 5
1 comentário
AirPods, those nifty wireless earbuds, are known for their convenience. But what if you misplaced their charging case? Unfortunately, unlike some phones that offer wireless charging capabilities, AirPods themselves lack that functionality. The charging case is integral – it not only stores your AirPods but also inductively charges them.
So, while the internet might be full of "hacks" for case-free charging, these are best avoided. They could potentially damage your AirPods or worse, cause a safety hazard.
If you're stuck without a case, your best options are to replace the case or consider a new pair of AirPods altogether.
You can see more:
https://support.apple.com/en-vn/guide/ai...
https://barcodelive.org/how-to-turn-on-a...
https://support.apple.com/en-vn/HT207012
por
Adicionar um comentário
2 respostas
Solução escolhida
So I am going to be 100% Honest and please bear with me
Now there is no way that this they can be charged without the case. Do not listen to any guides saying to put stuff in your airpods because you will damage them. The only solution is to get a replacement case, you can choose to get one from apple, or ebay. Only difference is cosmetic
You can connect them to a device without the case, if you connected to them before. The case charges the airpods and put them in setup mode for pairing.
PS - This below is a livesaver to help find the case when it goes missing
Esta resposta foi útil?
Pontuação 2
Just like driving a car with not fuel it is just not possible! You need to get a new case.
Pontuação 0
Adicionar a sua resposta
Loki Yt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 97
Últimos 30 dias: 509
Ao todo: 47,757
