Hi @nstrains
Plug in the USB flashdrive, start the laptop and get into BIOS (press F2)
When in BIOS check that under the Main tab, that Fast Boot is disabled. (When fast boot is enabled the USB ports aren't checked on startup).
Also check under the Boot tab that Secure Boot is disabled.
You should see the USB flashdrive listed as a boot option.
Save the changes and exit BIOS and restart the laptop.
When the laptop restarts press F12 and then select the USB drive as the desired boot device.
@nstrains
I doesn't help if you don't answer whether or not you've checked what I suggested above. If it still doesn't work then at least there are other things to try but unless you tell us we won't know!
Create a Win 10 recovery disc, either by downloading online or from any known working Win 10 PC.
In the host PC go to Control Panel > Recovery > Create a recovery disc and follow the prompts.
Doing either will create a bootable disc that you can install Win 10 from.
9 comentários
Hey NS, first how old is the USB, what color is the flat piece on the USB, and have you tried the USB on a different device?
por NR26
If you are trying to flash the bios then look in your manual for the bios flash USB.
por NR26
@nytryder26 I don't know how old the usb is and it does work on a different device and its a black PNY 8GB
por NS Trains
@nstrains Do you have an OS on the Acer?
por NR26
@nytryder26 windows 10, but it has some problems so I need a clean install
por NS Trains
Exibir mais 4 comentários
