Ir para o conteúdo principal
Apple's seventh-generation smartwatch, with optional cellular connectivity, released October 15, 2021.
Apple Watch Body Repair
Is the Nike Apple Watch Series 7 body and glass repairable?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The Nike Watch models are the same as the Apple Watch models for a parts other than the SIP unit which is programed with a slightly different ID string.
As for getting parts to do it your self or independent shop, so far the part supply is quite limited. I haven't found a source fo the display assembly which is a common repair.
If the case is also damaged then I would just go to an Apple Store to get your watch serviced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jeff Bennett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 470
