Ir para o conteúdo principal
O centro de café De'Longhi BCO430 é uma cafeteira combinada de expresso por bomba e café de filtro para 10 xícaras, com bico vaporizador, nas cores prata e preta.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Imagem
Imagem
Imagem
Did these images come ok?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
Esta resposta foi útil?
Pontuação 1
8 comentários:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
por
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Adicionar imagens a uma pergunta já existente
por
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
por
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
por
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
por
Exibir mais 3 comentários
These coffee makers often are similar. Compare to Remoção da caldeira da Saeco Magic Cappuccino SIN017 and Starbucks barista , perhaps it helps. Good luck!
Imagem de Starbucks Barista
Guia
Teardown da Starbucks Barista
Nível de dificuldade:
Moderado
Imagem de Saeco Magic Capuccino SIN017 Remoção da caldeira
Guia
Moderado
Pontuação 1
Pics attached - this is how far I could get
Update (10/08/2022)
Pontuação 0
Update (10/08/2022)
Imagem
Imagem
Imagem
Pontuação 0
Adicionar a sua resposta
liluet_hernandez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 509
