Ir para o conteúdo principal
Informações sobre reparo e desmontagem do topo de linha da Samsung, o S20 FE, lançado em outubro de 2020. Identificado pelo número de modelo SM-G780F ou SM-G780F/DSM
Rear Main Camera Replacement, Not working
I have a S20 FE model: SM-G780G that was completly smashed.
Replaced the Display + frame, moved over all small components from old frame to new one. Put in a new battery and a new back cover. Boot up the phone and do the diagnostic via *#0*#. Everything works except the rear main camera. There are some big spots on the sensor but the camera works. I ordered a new camera partnumber: GH96-13921A.
I install the new camera, open the camera app. Warning! Camera no working.
I install the old camera, No warnings, camera work but got spots in the picture.
Ordered another camera from a different supplier. Installed it and got the same error message.
Is the Rear Main camera paired to the motherboard? How can i pair a new camera?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I solved it.
Don't look at the Samsung partnumber for the camera. Take a look at the physical camera in your phone. On the flex cable that connects the camera to the motherboard there is a modelnumber. Either W12SAR2 or W12LAR2.
If the supplier you are buying the camera from do not list this specific information, ask them.
My original camera was a W12SAR2. I ordered the GH96-13921A (for the S20 FE 4G). The new camera wouldn't work as it was a W12LAR2.
I then bought a GH96-13893A (for the S20 FE 5G). This was a W12SAR2 camera. It worked!
Esta resposta foi útil?
Pontuação 3
1 comentário:
So you ordered a 4g camera instead of a 5g.
por
Adicionar a sua resposta
Nordway Store Kalmar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 1,532
