Ir para o conteúdo principal
Created November 5, 1955, by Doc Brown Enterprises
3 Perguntas Visualizar todos
My bath fan flux capacitor is interfering with my takion array.
Panasonic bath fan / light is not working. Model # FV-11VQL4 Light works but fan does not. Switched out the condenser. Still not working. Would rather not spend $300 on a new one.
Please call 858-357-7647
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @bca1962
Here's the wiring diagram for the unit from the service manual.
Use an Ohmmeter to check if the fan motor winding is OK or burnt out.
If the motor is faulty the part number is FFV3700234S (I think). Check on fan motor to verify. There is a parts list in the manual but it is for 3 models and maybe I linked the wrong number.
If the motor is faulty search online using the part number only to find suppliers that suit you best.
Is the interference still there with only the light on? If so it may be the ballast for the light. Happens sometimes with fluorescent lighting
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Tom B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 50
