Ir para o conteúdo principal
The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
20 Perguntas Visualizar todos
My phone is not charging
My s10e is not charging. Each time I I plug it in it shows a notification saying that the cable is not recognised. I have tried rebooting the device and using a different cable and power source. Should I replace the battery?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Ibrahim Hanif make sure that you do have a good cable and you could try an original. If that does not work you will have to check the power port. Clean it with a couple of drops of isopropyl Alcohol and some puffs of compressed air or equivalent. If that does not change anything your next step would be to replace the charging board.
A bad battery would not give you that type of error message. If you take your phone apart its always a good idea to change it anyway.
Esta resposta foi útil?
Pontuação 1
Probably damaged charge port,
Pontuação 0
Adicionar a sua resposta
Ibrahim Hanif será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 337
