Ir para o conteúdo principal
rapid clicking while trying to start
I replaced my starter and also solenoid and I still have rapid clicking while trying to start my cub cadet xt1. All terminals are clean and tight. Any suggestions on what else I can check.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
So that clicking is from the starter solenoid
Since the cables are fine and you replaced the starter, all I can think of is the battery. If you have a voltage meter, check to see if the battery is at 12.6. If it's not, let it charge overnight and try starting the mower again
Esta resposta foi útil?
Pontuação 0
1 comentário:
Mine is doing the exact same. Changed the starter, solenoid and battery. All wires are good and connections are good as well
por
Adicionar a sua resposta
PRESIDENT 4254 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 750
