Ir para o conteúdo principal
Informações de reparo e resolução de problemas para tratores cortadores de grama da marca Craftsman.
it quit moving forward or backwards
Our craftsman 2400 was working fine we started moving the grass and all of a sudden it quit moving forward or backwards all the keys to the tires are there , clean filter , brand new battery , new gas , oil. Don't know what the problem is
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There are a few things that could cause you to lose drive power
  1. Freewheel control is in the disengaged position
  2. Debris on the steering plate
  3. Motion drive belt worn
  4. Park brake engaged
Below is a manual for reference, hopefully this gets you up and going again
https://www.manualslib.com/products/Craf...
Esta resposta foi útil?
Pontuação 0
1 comentário:
My t2400 mows and moves fine at first then suddenly it quits pulling in drive and also in reverse. What can it be?
por
Adicionar a sua resposta
Mary será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 190
