Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 12. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 12.
Charging/ Lightning port on working
My charging port will not work to charge my phone. Headphones do not work with Lightning port either. Right now must charge phone wirelessly only. Can't find lightning port replacement part or instructions
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
if your in the us try mobilesentrix, uk/europe try headlane.co.uk
Esta resposta foi útil?
Pontuação 3
Hi
See this as something else to try In the meantime while you are seeing about getting your port fixed through the link that @tech_ni thanks fully provided:-)
Get a torch/flashlight and shine it into the port to check for dust and debris
If there is any get a sewing needle or some tweezers and carefully remove the dust and debris in the port(it can be surprising how much can fit in there!)
If that doesn’t work, turn your iPhone off and try a very small amount of isopropyl alcohol on a clean toothbrush and scrub away gently and the port to remove any corrosion that may stop it from charging,leave it to dry for a 30mins-hour just to be safe(just don’t get any on the lip between the screen and the chassis incase it gets in!
Hopefully this helps
Any questions please ask
Pontuação 2
Adicionar a sua resposta
aaronroesler será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 50
Ao todo: 506
