Ir para o conteúdo principal
Repair documentation for the initial Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
60 Perguntas Visualizar todos
L2 Button constant on even if not pushed
Hello,
i changed the two rings around the L3 button which caused stick drift , after getting all stuff together my L2 Button is like always enabled even if im not pushing it at all. How can i fix this ? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Try taking the controller apart again and then push the L2 button then release. If that doesn't work ,try replacing the trigger button. Hope this helps!
Diode
Esta resposta foi útil?
Pontuação 1
3 comentários:
tested some stuff and the L2 is even activated after i removed the left L1 and L2 unit from motherboard. So its something with the board i assume.
por
@Toni Montana Seems that way. All right. I don't know if I can help you in any other way. Sorry.
por
its a problem with the blue flat cable that connects the unit to the main board… try straightening the metals at the tip… worked for me
por
Adicionar a sua resposta
Toni Montana será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 159
Últimos 30 dias: 730
Duração total: 4,131
