Acer 11 C731 replaced charger port wire and still won't charge, help
Replaced Charger port on Acer 11 c731 and charger light won't go on or charge. Is there anything else I can do or charge this chromebook a different way?
Esta é uma boa pergunta?
In my experience, if replacing your DC-In Jack did not resolve your issues, there is most likely an issue with your machines motherboard, or battery.
In most cases, it may not be worth putting a lot more effort into fixing this issue, as the motherboard generally outweighs the cost of a new machine entirely.
Esta resposta foi útil?
Hi,
If you know how to use a DMM and how to read schematics then maybe consider buying them. Here's a supplier
Test the fuse near the port on the board.
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 116
4 comentários
did you try a different charger ?
por daniel
Yes multiple chargers and even tried multiple new ports
por Stephanie Adamietz
@Stephanie Adamietz then its more than likely an issue with the motherboard
por daniel
Thank you we decided to just replace these and keep them for parts.
